pull config/BuildSystem and rerun config/configure.py
Wed Jun 10 22:43:41 CDT 2009
    All petsc-dev users. Next time you pull petsc-dev make sure you
pull config/BuildSystem also and rerun your configure with $
{PETSC_ARCH}/conf/reconfigure-${PETSC_ARCH}.py
As always, report any problems to petsc-dev at mcs.anl.gov
    Barry
What I changed. I discovered the ar flags Sq that are much faster than
our current use of r. For my laptop these are the timings for "make
all" debug version
                 regular libraries           --with-single-library(new
config/configure.py option to put all code into libpetsc.a (not yet
working for shared libraries)).
old           9 min 23 sec                    28 min
new         2 min 49 sec                      2 min 58 sec
What I changed: added the flag FAST_AR_FLAGS that is used by libfast:
instead of AR_FLAGS; also added fast versions of buildmod called
buildmodfast that use libffast that uses FAST_AR_FLAGS
Once we get rid of the damn make we should see the entire "make all"
take less than a minute
