PCShell interface
Lisandro Dalcin dalcinl at gmail.com
Wed Jun 10 20:01:38 CDT 2009
On Wed, Jun 10, 2009 at 1:14 PM, Barry Smith<bsmith at mcs.anl.gov> wrote:
>   Go ahead. This has been on the todo list for a decade.
>   Remember to update dev.html with the change and change any examples that
> use PCShell.
>   Note you have to update the Fortran stubs for these beasts (some of the
> uglier stuff in PETSc.)
I've asked for this long, long, long ago... What Barry said is pasted
below (as my original post was sent to petsc-maint)... I agree that
the Fortran issues are a pain, but asking users to follow to the whole
beast of implementing a full PC subtype is also a pain (despite I
ended up doing that for petsc4py, and decided not to support PCShell).
from	Barry Smith <petsc-maint at mcs.anl.gov>
reply-to	petsc-maint <petsc-maint at mcs.anl.gov>
to	dalcinl at intec.unl.edu.ar
cc	petsc-maint <petsc-maint at mcs.anl.gov>
date	Tue, Dec 20, 2005 at 6:47 PM
subject	Re: [PETSC #14166] SetUp phase with PCShell
hide details 12/20/05
The current model for PCShell is that the PC is replaced with
the user context for all the methods, apply(), setup() etc.
We could change it everywhere to PC? One reason we have the current
model is for Fortran users where it is hard to pull something
out of a PETSc datastructure.
We actually expect people developing their own "serious" PC
to implement it directly and use PCRegisterDynamic() to register
it, instead of using PCSHELL. Is there a reason you don't want
to do it directly (using PCSHELL really isn't any easier, just
copy jacobi.c and change it for your new PC).
>    Barry
> On Jun 10, 2009, at 11:09 AM, Jed Brown wrote:
>> Matthew Knepley wrote:
>>> If I understand correctly, the objection is that apply for MatShell is
>>>  apply(Mat, Vec, Vec)
>>> and for PCShell is
>>>  apply(ctx, Vec, Vec)
>> Exactly.
>>> I agree that this is crap. Its an easy fix to jsut pass the PC instead of
>>> the ctx and let the user pull out the ctx manually if he wants. I am for
>>> this.
>> Great, I can do it.
>> Jed
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
