why not a single PETSc library
Jed Brown jed at 59A2.org
Tue Jun 9 18:15:16 CDT 2009
Dima Karpeev wrote:
> Don't .so's get loaded into memory as one whole piece?
They get mapped into virtual memory as one piece, but this doesn't mean
they are actually read from disk.  Then the dynamic linker does symbol
relocations for the symbols referenced by your app, but this also does
not require loading of the entire shared lib.  In general only the pages
of the shared lib that are used actually end up in physical memory.
To see this in action, run a tiny program that references a huge library
(debug PETSc would do).  The program may use lots of virtual memory (>
100 MB), but very little (< 10 MB) physical memory (RES).
So it's potentially an issue if you are using shared libs on a machine
with very limited virtual memory available (32-bit, or with a kernel
configured to not overcommit memory).  But since DM+SNES+TS is so small,
you would have to be extremely close to your system limits, asuming you
were already using KSP.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090610/ecf6c649/attachment.sig>
