why not a single PETSc library
Lisandro Dalcin dalcinl at gmail.com
Tue Jun 9 17:19:12 CDT 2009
On Tue, Jun 9, 2009 at 6:59 PM, Matthew Knepley<knepley at gmail.com> wrote:
> I would ask: why is anything ever split up? Why not just munge everything in
> the
> entire Linux distribution into one big fat library?
>   Matt
Mat, that's is not a fair example...
A single library will solve a problem you can exercise with the Python
code below (using a shared libs build)
import os
PETSC_DIR = os.getenv('PETSC_DIR')
PETSC_ARCH = os.getenv('PETSC_ARCH')
PETSC_LIB_DIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'lib')
import ctypes
MODE = ctypes.RTLD_LOCAL
#MODE = ctypes.RTLD_GLOBAL
libpetsc    = ctypes.CDLL(os.path.join(PETSC_LIB_DIR, 'libpetsc.so'), mode=MODE)
libpetscvec = ctypes.CDLL(os.path.join(PETSC_LIB_DIR,
'libpetscvec.so'), mode=MODE)
The only way you can dlopen() PETSc libraries is by using RTLD_GLOBAL
(uncomment an you will see it works in that case).
Moreover, see this, just run on my rather old box, with a debug build
and many external packages (= big libraries):
$ time python -c "from petsc4py import PETSc"
real	0m0.791s
user	0m0.175s
sys	0m0.081s
real	0m0.341s
user	0m0.199s
sys	0m0.072s
So the time required to load the whole PETSc (at least what petsc4py
uses, that IMHO is a lot) is really tiny compared to any practical
run.
> On Tue, Jun 9, 2009 at 4:55 PM, Jed Brown <jed at 59a2.org> wrote:
>> Barry Smith wrote:
>> > On Jun 9, 2009, at 4:37 PM, Matthew Knepley wrote:
>> >> I think its legitimate to only want some of our crap.
>> >    You only get what you use; if you only use KSP then only the KSP and
>> > below stuff will be pulled into your program, so what is the problem?
>> With shared libs, you always get the whole thing.  Of course, the unused
>> part may only be mapped into virtual memory (thus never physically
>> present).  I suspect it's fairly rare to use less than Mat or KSP at
>> which point the presence of SNES/TS/DM is minimal overhead.  A single
>> lib is certainly easier to find with configure scripts.
>> Jed
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
