hypre
Mon Jun 8 16:27:17 CDT 2009
On Mon, 8 Jun 2009, Giuseppe Ghibò wrote:
> Barry Smith wrote:
> >    1) you probably don't need shared libraries
> Well, I'd like to built both shared and static libraries of petsc.
> >    2) Did you run config/configure.py with the option --with-shared,
> > if not they are turned off by default
> yep, --with-shared=1 was already enabled.
Perhaps you have a typo.. I just verified - the build works for me..
If it doesn't work for you - send us the relavent logs [configure.log
make_linux.log] to petsc-maint at mcs.anl.gov
Satish
