Setting options on matrices obtained from a DM
Jed Brown jed at 59A2.org
Wed Jul 22 12:08:59 CDT 2009
Lisandro Dalcin wrote:
> If you do MatSetType(A, MATAIJ), you end-up having a MATSEQAIJ or a
> MPIMPIAIJ... Vec does not have such "aliasing" on type names ...
How is this a problem?  You aren't matching type names, you're just
setting a function to be called after the sizes are known.  Since this
happens in MatCreate_{Seq,MPI}AIJ, it doesn't matter whether MatSetType
was called with MATAIJ.
Also note that we currently have mat->ops->setsizes (only implemented by
SeqDense) so we should either use it or remove it, as long as we value
one-way-to-do-it.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090722/9135cfd4/attachment.sig>
