Setting options on matrices obtained from a DM
Lisandro Dalcin dalcinl at gmail.com
Wed Jul 22 09:56:29 CDT 2009
On Wed, Jul 22, 2009 at 12:20 AM, Barry Smith<bsmith at mcs.anl.gov> wrote:
> On Jul 21, 2009, at 7:47 PM, Jed Brown wrote:
>> Barry Smith wrote:
>    This is just a limitation of the current implementation due to the way
> the design evolved over time.
> There is nothing intrinsic to the abstract design of PETSc that prevents the
> type from being
> properly processed before the sizes are set.
I agree 100% with you.. the only issue are tons of code to review and fix :-(
>   This is really yucky API you propose here; that no sane person would
> propose except to work
> around a shortfall in the current implementation.
We could start fixing Vec, next go for Mat ...
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
