Setting options on matrices obtained from a DM
Jed Brown jed at 59A2.org
Tue Jul 21 19:00:40 CDT 2009
Barry Smith wrote:
>     My eventual goal is to remove all "hidden" MatCreate()'s and
> instead have Mat's passed in as arguments. So MatLoad() would take a
> Mat as an argument, as would DAGetMatrix() One could then set as much
> or a as little as a Mat as they like before passing it in.  They could
> set the type, they could set the sizes, they could set the prefix.
Right, though setting sizes before DAGetMatrix() wouldn't be meaningful.
>    I think this is the direction you want? Will it satisfy all your needs?
>    MatCreate().
>    MatSetOptionsPrefix()
>    MatSetFromOptions()
>    DAGetMatrix()
This will work at present, but it's not perfect (without Mat
adjustments).  Some options would be set as a consequence of the
MatSetSizes() which occurs within DMGetMatrix() (ops->create() is saved
until the sizes are known).  If a matrix type implements
MatSetFromOptions (currently just SchurComplement), that function would
never get called in this scheme (because that operation won't be set
until the sizes are known).  This could be handled by modifying the
matrix types so that MatCreate_XXX() could be called before
MatSetSizes(), but this is nontrivial.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090722/1bfbe283/attachment.sig>
