script to query PETSc makefile variables?
Thu Jan 22 18:18:49 CST 2009
On Jan 22, 2009, at 6:17 PM, Matthew Knepley wrote:
> I meant something slightly different. I mean that the 'script' module
> is really doing very
> little work in this example. It is only processing command line
> options. Retreiving the
> variables will work with only standard Python.
    So take out the dependency.
    Barry
>  Matt
>> Boyana
>>>  Matt
>>>> Boyana
>>>>> On Thu, Jan 22, 2009 at 5:15 PM, Boyana Norris
>>>>> <norris at mcs.anl.gov>
>>>>> wrote:
>>>>>> Thank you both -- I'd prefer to use configVars.py, but it seems
>>>>>> to
>>>>>> depend
>>>>>> on
>>>>>> the script module, which is not standard in at least Python 2.5.
>>>>>> Googling
>>>>>> for "python script module" is a joke, as you can imagine. Is
>>>>>> this a
>>>>>> PETSc
>>>>>> thing or a general module I can get somewhere?
>>>>> That module is in PETSc,
>>>>> $PETSC_DIR/config/BuildSystem
>>>>>  Matt
>>>>>> Thanks!
>>>>>> Boyana
>>>>>>> Check out $PETSC_DIR/bin/configVars.py
>>>>>>> Matt
>>>>>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay
>>>>>>> <balay at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>>>>>> Is there a script that can be used to query the values of
>>>>>>>>> various
>>>>>>>>> variables
>>>>>>>>> defined in petscvariables makefile snippets (similar to lots
>>>>>>>>> of
>>>>>>>>> linux
>>>>>>>>> tools'
>>>>>>>>> pkg-config scripts)?
>>>>>>>> [don't have canned code for this but] I've previously
>>>>>>>> recommended
>>>>>>>> doing the following in the packages configure.. [facets now
>>>>>>>> has this
>>>>>>>> in their configure to detect petsc]
>>>>>>>> - petsc_arch and petsc_dir are inputs to configure
>>>>>>>> - Create a dummy makefile on the fly
>>>>>>>> - run this makefile to echo relavent stuff..
>>>>>>>> For eg:
>>>>>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>>>>>> #!/bin/sh
>>>>>>>> PETSC_ARCH=asterix64
>>>>>>>> PETSC_DIR=/home/balay/spetsc
>>>>>>>> cat <<EOF > petscmake
>>>>>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>>>>>> PETSC_DIR  = ${PETSC_DIR}
>>>>>>>> include ${PETSC_DIR}/conf/base
>>>>>>>> EOF
>>>>>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>>>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>>>>>> echo '**** PETSC_INC ***'
>>>>>>>> echo ${PETSC_INC}
>>>>>>>> echo '**** PETSC_LIB ***'
>>>>>>>> echo ${PETSC_LIB}
>>>>>>>> Satish
>>>>>> Boyana Norris, Computer Scientist    |   Email:
>>>>>> Argonne National Laboratory          |   Phone: +1 (630) 252 7908
>>>>>> http://www.mcs.anl.gov/~norris/      |   Fax:   +1 (630) 252 5986
>>>> Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
