script to query PETSc makefile variables?
Boyana Norris norris at mcs.anl.gov
Thu Jan 22 17:34:53 CST 2009
Barry Smith wrote:
>     The danger is that the PETSc conf/variables makefile defines its
> own variables based on various variables that
> are defined in PETSC_ARCH/conf/petscvariables hence the "raw" variable
> values from running config/configure.py may not
> always be what you need.
Actually that is exactly the reason I wanted the script. I don't want
*all* the variables, just a couple. If I just include the petscvariables
file in my makefile, all hell breaks lose since there are lots of
conflicts in variable names (the curse of everybody being "good" and
following the gnu model).
>    Yes, this situation has to be fixed. There are too many levels of
> complexity and how can anyone keep track of things, what a mess.
> Satish doesn't agree but I think the logic and defines in
> conf/variables needs to be removed into the config/configure.py system
Having both would make everyone happy, if it can be done without
duplicating information.
Boyana
>    Barry
> On Jan 22, 2009, at 5:15 PM, Boyana Norris wrote:
>> Thank you both -- I'd prefer to use configVars.py, but it seems to
>> depend on the script module, which is not standard in at least Python
>> 2.5. Googling for "python script module" is a joke, as you can
>> imagine. Is this a PETSc thing or a general module I can get somewhere?
>> Thanks!
>> Boyana
>> Matthew Knepley wrote:
>>> Check out $PETSC_DIR/bin/configVars.py
>>>  Matt
>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>> Is there a script that can be used to query the values of various
>>>>> variables
>>>>> defined in petscvariables makefile snippets (similar to lots of
>>>>> linux tools'
>>>>> pkg-config scripts)?
>>>> [don't have canned code for this but] I've previously recommended
>>>> doing the following in the packages configure.. [facets now has this
>>>> in their configure to detect petsc]
>>>> - petsc_arch and petsc_dir are inputs to configure
>>>> - Create a dummy makefile on the fly
>>>> - run this makefile to echo relavent stuff..
>>>> For eg:
>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>> #!/bin/sh
>>>> PETSC_ARCH=asterix64
>>>> PETSC_DIR=/home/balay/spetsc
>>>> cat <<EOF > petscmake
>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>> PETSC_DIR  = ${PETSC_DIR}
>>>> include ${PETSC_DIR}/conf/base
>>>> EOF
>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>> echo '**** PETSC_INC ***'
>>>> echo ${PETSC_INC}
>>>> echo '**** PETSC_LIB ***'
>>>> echo ${PETSC_LIB}
>>>> Satish
>> Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
>> Argonne National Laboratory          |   Phone: +1 (630) 252 7908
>> http://www.mcs.anl.gov/~norris/      |   Fax:   +1 (630) 252 5986
