avoiding incorrect code
Wed Jan 14 16:00:28 CST 2009
On Jan 14, 2009, at 3:37 PM, Satish Balay wrote:
> There are tonnes of places in PETSc with this usage [which I guess is
> fixable].
    I have already pushed to petsc-3.0.0 the fixes for this. Virtually
all were Matt's
fault in strange parts of the code no body uses so they don't matter
and then in
the VecSetValues_ code.
> But imposing coding guidelines [which are unenforceable] to hide
> compiler differences is a bad policy..
      This has nothing to do with compiler differences; just because
some Fortran
compilers use the bit pattern of 1 for .true. and some use -1 does not
change
the fact that a PetscTruth value of 0 is false while any other value
is true.
   Using integers as boolean on the Fortran side is a perversity that
had to be
fixed.
> It will continue to waste
> time..
   In C the test if (something) and if (!something) means in the first
case
if the value of something is NOT 0 and the second means the value of
something
is 0. Hence, since C does not have a boolean value traditionally
people have
taken true to be any nonzero value and false to be the zero value. In
fact,
if you stick any nonzero value into a Fortran boolean it will treat it
as true;
so Fortran also follows this paradigm. It is just when .true. is used,
the bit string
of 1 or -1 is put in.
   I don't know where the == PETSC_TRUE nonsense came from, it could be
my fault. But the coding standard has been there for many years and most
== PETSC_TRUE stuff was removed years ago.
   Barry
> Satish
> On Wed, 14 Jan 2009, Barry Smith wrote:
>>  From the PETSc developers guide
>> Do not use {\em if (rank == 0)} or {\em if (v == PETSC\_NULL)} or
>> {\em if (flg
>> == PETSC\_TRUE)} or {\em if (flg == PETSC\_FALSE)}
>> instead use {\em if (!rank)} or {\em if (!v)} or {\em if (flg)} or
>> {\em if
>> (!flg)}.
>> There was a flag == PETSC_TRUE in PETSc 3.0.0 that wasted a lot of
>> several
>> peoples time finding it. Come on folks, we have better things to do
>> with our
>> time. Please avoid this incorrect usage.
>>  Barry
