A (likely spurious) GCC warning (building in Ubuntu 9.04)
Lisandro Dalcin dalcinl at gmail.com
Sat Aug 15 18:52:53 CDT 2009
This warning is from petsc-release-3.0.0 ... Can any of you fix it by
just initialising  the var to zero where it is declared?
libfast in: /usr/local/petsc/3.0.0/src/mat/impls/aij/mpi
mpiaij.c: In function ‘MatLoad_MPIAIJ’:
mpiaij.c:2806: warning: ‘maxnz’ may be used uninitialized in this function
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
