std::complex instantiation
Lisandro Dalcin dalcinl at gmail.com
Mon Sep 8 13:50:00 CDT 2008
On Mon, Sep 8, 2008 at 3:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   This may be a correct change, but currently the only support for complex
> in PETSc is for
> double complex. Likely many changes are needed (like with Blas/Lapack) to
> support single complex
> or quad complex.
Then the various definitions of PetscScalar in 'include/petscmath.h'
are just placeholders for the future?
>   Barry
> On Sep 8, 2008, at 1:26 PM, Lisandro Dalcin wrote:
>> In 'src/sys/objects/init.c', we have
>> #if defined(PETSC_COMPLEX_INSTANTIATE)
>> template <> class std::complex<double>; /* instantiate complex template
>> class */
>> #endif
>> Is this right? I believe it should be (regarding 'include/petscmath.h')
>> template <> class std::complex<PetscReal>;
>> or perhaps better:
>> #if defined(PETSC_USE_SINGLE)
>> template <> class std::complex<float>;
>> #elif defined(PETSC_USE_LONG_DOUBLE)
>> template <> class std::complex<long double>;
>> #elif defined(PETSC_USE_INT)
>> template <> class std::complex<int>;
>> #else
>> #endif
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
