Need help adding a new solver to the petsc library
Hong Zhang hzhang at mcs.anl.gov
Fri Nov 21 09:43:09 CST 2008
>> I managed to run ex19 on the solver PaStiX like it is done for mumps but my
>> matrix must be badly constructed (PaStiX doesn't succeed in computing  the
>> solution withe the given problem...).
>> Is there a way to dump the MPIAIJ matrix into a matrixmarket format so that
>> I can check what's wrong with the CSC built ?
>  No we don't have any matrix output to matrixmarket format.
> Does the code run correctly on 1 process?
We have a code that converts MatrixMarket format to PETSc binary.
If you are interested, I can forward to you.
Hong
>> Second question, in the petsc-dev/config/PETSc/packages/Scotch.py I wrote,
>> do I have a way to check if libz.a is present, so that I can decide if I
>> compile with -DCOMMON_FILE_COMPRESS_GZ and -lz ? (libz.a requirement is
>> depending of an optional feature of Scotch...)
> In your PaStiX.py you can add something like
>   if self.libraries.add('-lz','function_in_library'):
>     self.addDefine('HAVE_WHAT_YOU_WANT_STRINGH',1)
> Barry
>> thanks,
>> XL.
>> Barry Smith a écrit :
>>>    Take a look at, for example, MatGetFactor_MPIAIJ_mumps (in
>>> src/mat/impls/aij/mpi/mumps)
>>> you will need to create one for pastix and then take a look at
>>> MatCreate_MPIAIJ and see
>>> how the mumps function is registered, you will need to register in the
>>> same way.
>>>   Barry
>>> On Nov 7, 2008, at 10:07 AM, Xavier Lacoste wrote:
>>>> Hello,
>>>> I'm still working on adding PaStiX into PETSc.
>>>> I managed to pass the configure and "make all test" steps.
>>>> (./config/configure.py -with-scotch=1 -download-scotch=ifneeded
>>>> -with-pastix -download-pastix=ifneeded )
>>>> Here are the modification I made on petsc-dev version 12911:0e70d56474b2
>>>> http://dept-info.labri.fr/~lacoste/petsc/adding_pastix_12911_0e70d56474b2.patch
>>>> - I added PaStiX.py package
>>>> - I modified Scotch.py package to use last version
>>>> - I modified partition/impls/scotch.c so that it compiles (it would not
>>>> work in the current state)
>>>> - I had aij/mpi/pastix/pastix.c file to make an interface to pastix.
>>>> - I tried to use example 19 with pastix, like it is done with mumps but
>>>> pastix solver is not found :
>>>> http://dept-info.labri.fr/~lacoste/petsc/error_log
>>>> Now, I have to know how to tell petsc it has a new solver implementing
>>>> mpiaij.
>>>> How can I do that ?
>>>> After that I should be able to test if my implementation of mpiaij matrix
>>>> is working or not.
>>>> Thanks,
>>>> XL.
>>>>> Please send your $PETSC_ARCH/conf/configure.log and
>>>>> $PETSC_ARCH/conf/make.log to petsc-maint at mcs.anl.gov (not to this email
>>>>> address)
>>>>> and we'll take a look.  Also send your modified Scotch.py file.
>>>>> Thanks
>>>>> Barry
>>>>> On Nov 3, 2008, at 10:45 AM, Xavier Lacoste wrote:
>>>>>> Hello,
>>>>>> I want to add the solver PaStiX
>>>>>> (https://gforge.inria.fr/projects/pastix/) to the PETSc library.
>>>>>> I Check-outed the last hg version of PETSc and started adding my
>>>>>> PaStiX.py script, based on MUMPS one, in
>>>>>> petsc-dev/config/PETSc/packages/ .
>>>>>> I modified first Scotch.py wich wasn't updated because PaStiX needs
>>>>>> Scotch.
>>>>>> My problem is that I couldn't succed in configuring PETSCc with
>>>>>> "--with-pastix=1 etc." because i don't know how to say PETSc that
>>>>>> PaStiX needs the "-L/Scotch/dir -lscotch etc."
>>>>>> I have the setupDependencies :
>>>>>> def setupDependencies(self, framework):
>>>>>> PETSc.package.Package.setupDependencies(self, framework)
>>>>>> self.mpi        = framework.require('config.packages.MPI',self)
>>>>>> self.blasLapack = framework.require('config.packages.BlasLapack',self)
>>>>>> self.scotch     = framework.require('PETSc.packages.Scotch',self)
>>>>>> self.deps       = [self.mpi,self.blasLapack,self.scotch]
>>>>>> return
>>>>>> But it didn't helped, the -L/scotchdir/lib is still missing...
>>>>>>> Executing: mpicc  -o conftest    -g  conftest.o
>>>>>>> -Wl,-rpath,/home/xl/pastix/lib -L/home/xl/pastix/lib -lpastix
>>>>>>> -lpthread -lscotch -llapack -lblas *
>>>>>>> -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/lib -ldl -lgcc_s
>>>>>>> -lgfortranbegin -lgfortran -lm -L/usr/lib/gcc/i486-linux-gnu/4.3.2
>>>>>>> -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/usr/lib/gcc/i486-linux-gnu
>>>>>>> -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/lib -L/lib -lm
>>>>>>> -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/lib -ldl -lgcc_s -ldl
>>>>>>> sh:
>>>>>>> Possible ERROR while running linker: /usr/bin/ld: cannot find -lscotch
>>>>>> Hope i'm on the good Mailing list for this kind of questions.
>>>>>> Thanks
>>>>>> XL.
>>>>>> PaStiX team, INRIA-Bordeaux-Sud-Ouest, France.
