Checkpoint in PETSc
Santolo Felaco ahuramazda10 at gmail.com
Fri Nov 21 07:52:05 CST 2008
Hi, I have to implement the checkpoint of function KSPSolve_CG.
I have many problem.
1- Can I to duplicate the KSP object? Can I send the KSP objcet to
checkpoint process?
2 - I'm using FT-MPI, in case of fault can I set (do not recreate) the new
communicator to object of alive process?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20081121/3d52a5d4/attachment.html>
