want to make some changes to PCASM
Lisandro Dalcin dalcinl at gmail.com
Thu Nov 20 15:59:34 CST 2008
I would like to make some changes and enhancements in PCASM:
1) Make it take full ownership (allocated array memory and IS
references) of the subdomain index sets.
2) Currently, if the matrix is symmetric, ASM switches to type
PC_ASM_BASIC in PCSetFromOptions_ASM().
I believe this should also be handled on PCSetup_ASM(). If not, we get
different behavior if PCSetFromOptions() is never called.
Moreover, I believe PCSetFromOptions_ASM() should call PCASMSetType()
if the '-pc_asm_type' option is passed.
3) If more than one block per processor is requested, then ASM
currently does a row-based partitioning. For unstructured problems and
LU-based local solves, this is going to be really bad, right?
I've already implemented an 'smart' subdomain partitioner based on
MatPartitioningXXX. I'm thinking about adding a new utility routine
(in the spirit of PCASMCreateSubdomains2d)
PCASMCreateSubdomains(Mat A, MatPartitioningType mptype, PetscInt
local_blocks, IS *is[])
which could be called in order to get a good subdomain partitioning,
and next pass it to PCASMSetLocalSubdomains().
Does all this make sense?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
