Need help adding a new solver to the petsc library
Fri Nov 7 13:21:01 CST 2008
      Take a look at, for example, MatGetFactor_MPIAIJ_mumps (in src/
mat/impls/aij/mpi/mumps)
you will need to create one for pastix and then take a look at
MatCreate_MPIAIJ and see
how the mumps function is registered, you will need to register in the
same way.
     Barry
On Nov 7, 2008, at 10:07 AM, Xavier Lacoste wrote:
> Hello,
> I'm still working on adding PaStiX into PETSc.
> I managed to pass the configure and "make all test" steps.
> (./config/configure.py -with-scotch=1 -download-scotch=ifneeded -
> with-pastix -download-pastix=ifneeded )
> Here are the modification I made on petsc-dev version
> 12911:0e70d56474b2
> http://dept-info.labri.fr/~lacoste/petsc/adding_pastix_12911_0e70d56474b2.patch
> - I added PaStiX.py package
> - I modified Scotch.py package to use last version
> - I modified partition/impls/scotch.c so that it compiles (it would
> not work in the current state)
> - I had aij/mpi/pastix/pastix.c file to make an interface to pastix.
> - I tried to use example 19 with pastix, like it is done with mumps
> but pastix solver is not found :
> http://dept-info.labri.fr/~lacoste/petsc/error_log
> Now, I have to know how to tell petsc it has a new solver
> implementing mpiaij.
> How can I do that ?
> After that I should be able to test if my implementation of mpiaij
> matrix is working or not.
> Thanks,
> XL.
> Barry Smith a écrit :
>>   Please send your $PETSC_ARCH/conf/configure.log and $PETSC_ARCH/
>> conf/make.log to petsc-maint at mcs.anl.gov (not to this email address)
>> and we'll take a look.  Also send your modified Scotch.py file.
>>  Thanks
>>   Barry
>> On Nov 3, 2008, at 10:45 AM, Xavier Lacoste wrote:
>>> Hello,
>>> I want to add the solver PaStiX (https://gforge.inria.fr/projects/pastix/
>>> ) to the PETSc library.
>>> I Check-outed the last hg version of PETSc and started adding my
>>> PaStiX.py script, based on MUMPS one, in petsc-dev/config/PETSc/
>>> packages/ .
>>> I modified first Scotch.py wich wasn't updated because PaStiX
>>> needs Scotch.
>>> My problem is that I couldn't succed in configuring PETSCc with "--
>>> with-pastix=1 etc." because i don't know how to say PETSc that
>>> PaStiX needs the "-L/Scotch/dir -lscotch etc."
>>> I have the setupDependencies :
>>> def setupDependencies(self, framework):
>>>  PETSc.package.Package.setupDependencies(self, framework)
>>>  self.mpi        = framework.require('config.packages.MPI',self)
>>>  self.blasLapack =
>>> framework.require('config.packages.BlasLapack',self)
>>>  self.scotch     = framework.require('PETSc.packages.Scotch',self)
>>>  self.deps       = [self.mpi,self.blasLapack,self.scotch]
>>>  return
>>> But it didn't helped, the -L/scotchdir/lib is still missing...
>>> > Executing: mpicc  -o conftest    -g  conftest.o  -Wl,-rpath,/
>>> home/xl/pastix/lib -L/home/xl/pastix/lib -lpastix -lpthread -
>>> lscotch -llapack -lblas *
>>> > -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/lib -ldl -lgcc_s -
>>> lgfortranbegin -lgfortran -lm -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -
>>> > -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/usr/lib/gcc/i486-linux-
>>> gnu -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/usr/lib/gcc/i486-linux-
>>> gnu
>>> > -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/lib -L/lib -lm -L/usr/lib/
>>> gcc/i486-linux-gnu/4.3.2 -L/usr/lib/gcc/i486-linux-gnu/4.3.2 -L/
>>> lib -ldl -lgcc_s -ldl
>>> > sh:
>>> > Possible ERROR while running linker: /usr/bin/ld: cannot find -
>>> lscotch
>>> Hope i'm on the good Mailing list for this kind of questions.
>>> Thanks
>>> XL.
>>> PaStiX team, INRIA-Bordeaux-Sud-Ouest, France.
