initialization of XXX_COOKIE in C source files
Sun May 11 07:48:44 CDT 2008
> Now I am a little worried. Don't some compilers dislike
> unintialized, file scope
> variables in shared libraries (I am thinking AIX).
>  Matt
     If the need arises I will put all the = 0 back in.
     We never got AIX shared libraries to work anyways :-)
    Barry
On May 11, 2008, at 7:07 AM, Matthew Knepley wrote:
> On Sat, May 10, 2008 at 7:49 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> On May 10, 2008, at 6:08 PM, Lisandro Dalcin wrote:
>>> I've noticed that in 2.3.3 all PETSc cookies are initialized to zero
>>> in sources, but in DEV they are not initialized. What's the reason
>>> of
>>                                    You are quick, I just pushed the
>> change
>> last night.
>>    The reason why they where all initialized to zero was because
>> - a very long time ago all the cookies where hardwired numbers that
>> we
>>   chose for each new class
>> - then we added the ability to request a cookie, but still support
>> the old
>>  hardwired version. Passing in a pointer to a zero value meant you
>> were
>>  requesting one, passing in a pointer to a nonzero one meant that the
>> cookie
>>  had a hardwired value.
>> - over time all the hardwired ones were unhardwired, but the
>> convention
>>  of initializing them to zero before hand was never changed.
>>  There was some convoluted logic for why the PetscEvent values were
>> all initialized to zero also. When fixing up the events I also
>> fixed the
>> cookies
>> The reason is Barry's rule # 54, "nothing should be done in a code
>> without
>> a reason, otherwise it will be confusing to others looking at the
>> code."
>> For example,
>> even now, whenever anybody made some new events they initialized them
>> to zero, why? Not because they need to be, but simply because they
>> were in
>> code the developer copied from.
>>  Were you taking advantage of their initialization to zero? If so,
>> rather
>> than depending
>> on each cookie being initialized to zero I would suggest handling
>> this type
>> of "check if initialized" stuff at a package by package level or
>> library by
>> library level.
>> Please let me know what you need.
>  Matt
>>  Barry
>>> this change?
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>> (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
