How come it is PetscEvent but all the routines that act on it are PetscLogEventXXXX()?
Richard Tran Mills rmills at ornl.gov
Wed May 7 10:48:06 CDT 2008
Barry,
I like the the suggestion to change PetscLogEvent* to PetscEvent*, but to be
consistent with naming then I think we would also need to change
PetscLogStage* to PetscStage*, etc.
Just my 0.5 cents.
--Richard
Barry Smith wrote:
> On May 5, 2008, at 7:39 PM, Matthew Knepley wrote:
>> Actually, I would argue that these methods do not actually act on
>> PetscEvent
>> at all (which is just an integer), but rather on a PetscLog. That is
>> why I named
>> them that way.
>    The namage has to be consistent with any normal Joe's thinking about
> the usage,
> not based on some implementation issue that only you know about. Names
> are for
> users, not for the guru developers. Guru developers could name their
> variables and
> functions a1 to a2303 and have no problem maintaining the code.
>   I think the macro names should be changed to PetscEventBegin.... not
> PetscLogEventBegin.... based on the policy in PETSc that "methods" on
> "objects"
> start with the name of the objects: e.g. MatMult(Mat,....) The user
> shouldn't know
> or care that PetscEvent is an int and not a PetscEvent or PetscLogEvent
> object.
>    Barry
> We could instead change PetscEvent to PetscLogEvent but I think PetscEvent
> is clear enough without the Log in it.
>>  Matt
>> On Sat, May 3, 2008 at 6:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Doesn't seem right.
>>>   Barry
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
Richard Tran Mills, Ph.D.            |   E-mail: rmills at climate.ornl.gov
Computational Scientist              |   Phone:  (865) 241-3198
Computational Earth Sciences Group   |   Fax:    (865) 574-0405
Oak Ridge National Laboratory        |   http://climate.ornl.gov/~rmills
