petscvariables: hardwired build dir instead of install dir
Sat Mar 22 18:14:39 CDT 2008
Lisandro
    The rule was a total mess; I think I have fixed it now, please try
again
and let me know how it goes.
   Thanks for reporting the problem,
    Barry
On Mar 22, 2008, at 1:18 PM, Lisandro Dalcin wrote:
> OK, it seems my stderr were being sent I do not know were... I get the
> following (BTW, I was not aware of the 'sed' trick, but I was not
> seeing the error)
> [root at trantor petsc-dev]# make install
> Installing PETSc at /usr/local/petsc/dev/linux-gnu
> sed: can't read s?${PETSC_DIR}?TMP_INSTALL_DIR?g: No such file or
> directory
> sed: can't read s?TMP_INSTALL_DIR?/usr/local/petsc/dev/linux-gnu?g: No
> such file or directory
> sed: can't read s?/${PETSC_ARCH}??g: No such file or directory
> making shared libraries in /usr/local/petsc/dev/linux-gnu//lib
> building libpetsc.so
> building libpetscvec.so
> building libpetscmat.so
> building libpetscdm.so
> building libpetscksp.so
> building libpetscsnes.so
> building libpetscts.so
> building libpetsccontrib.so
> sh/bash: PETSC_DIR=/usr/local/petsc/dev/linux-gnu; export PETSC_DIR
> sh/bash: unset PETSC_ARCH
> csh/tcsh: setenv PETSC_DIR  /usr/local/petsc/dev/linux-gnu
> csh/tcsh: unsetenv PETSC_ARCH
> Then do make test to verify correct install
> And then the 'petscvariables' still have the build dir in many places.
> So the 'sed' command is not working for me. I do not know way, I've
> never had the time to learn regexps :-(.
> BTW, I'm on a Fedora 6 box.
> On 3/22/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Ok, I think I understand your concern,
>>>>     Do you mean that it lists, for example,
>>>> SUPERLU_DIST_LIB = -Wl,-rpath,/Users/bsmith/Src/petsc-dev/arch-icc-
>>>> superlu_dist/lib -L/Users/bsmith/Src/petsc-dev/arch-icc-
>>>> superlu_dist/
>>>> lib -lsuperlu_dist_2.2
>>>> instead of
>>>> SUPERLU_DIST_LIB = -Wl,-rpath,$PETSC_DIR/arch-icc-superlu_dist/
>>>> lib -L
>>>> $PETSC_DIR/arch-icc-superlu_dist/lib -lsuperlu_dist_2.2
>>> exactly that, as an example, I've just built petsc-dev, passing as
>>> prefix the following '--prefix=/usr/local/petsc/2.3.3/linux-
>>> gnu' (yes,
>>> I still want to have multiconfig installations of petsc in a central
>>> location, so I add the PETSC_ARCH to the prefix)
>>> But the 'petscvariables' file stills says, for example
>>> ML_INCLUDE = -I. -I/usr/local/mpich2/1.0.6/include
>>> -I/repos/hg/petsc/petsc-dev/linux-gnu/include
>>    This is because the place we want ML to install itself has be
>> passed in as the true path, it cannot be sent as a symbolic PETSC_DIR
>> since configure of the subpackage doesn't know PETSC_DIR
>>> The last include dir is the directory were I've built PETSc. I would
>>> love to see that include as -I${PETSC_DIR}/${PETSC_ARCH}/include.
>>> And
>>> now, if external packages got installed in $PETSC_DIR/$PETSC_ARCH,
>>> we
>>> perhaps could just put nothing, as that location is always taken
>>> into
>>> accout for PETSc itself.
>>> The real problem: if I remove the build dir, the 'petscvariables'
>>> point to locations that no longer exists, This is dangerous. I
>>> already
>>> had trouble in the past with the old 'bmake' based system. Is
>>> there a
>>> chance to 'fix' this, or I'm missing something?
>>   make intall: see the rule in makefile is suppose to replace all
>> uses of the
>> petsc-dir directory with the final prefix installed location: the
>> lines
>>           sed -i "" 's?$${PETSC_DIR}?TMP_INSTALL_DIR?g' $
>> {INSTALL_DIR}/conf/* ;\
>>           sed -i "" s?TMP_INSTALL_DIR?${INSTALL_DIR}?g $
>> {INSTALL_DIR}/
>> conf/* ;\
>> would replace
>> /usr/local/petsc/2.3.3/linux-gnu/include
>> Now it could be that the sed is not working when you run install? Can
>> you do a
>> config/configure.py with a --prefix then the make then the make
>> install and see what
>> goes wrong?
>>   Barry
>> with
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>> (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
