configuring with --prefix
Lisandro Dalcin dalcinl at gmail.com
Fri Mar 21 16:53:51 CDT 2008
I got this error at configuration time:
You do not have write access to create install directory given with
--prefix=/usr/local/petsc/dev/linux-gnu perhaps use --with-sudo=sudo
also
Then I've added, the sudo stuff and worked. However, after the
configuation, the dir was not created. So the question is: in which
scenario PETSc does need access to the install dir at configuration
time?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
