#define XXXType const char* ----> #define XXXType char* ?
Lisandro Dalcin dalcinl at gmail.com
Mon Jun 23 14:38:59 CDT 2008
On 6/23/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   A while ago I made XXType (MatType, VecType etc) const char*
Well, you actually did
#define VecType const char*
instead of
typedef const char* VecType;
which IMHO is the right way.
>    I now think that was a mistake.
Yep, the '#define' way can cause problems ;-)
> I'd like to change them to just  char*
But why not the 'typedef' way ??
>   Can anyone suggest a technical reason why this is a bad idea before I push
> the code?
>  Note this means if you have code like
>    VecType t = VECMPI;
>  you would need to change it to
>    const VecType t = VECMPI;
Mmm, just a bit ugly you have to add the 'const' keyword. I insist:
What would be the problem with ... ??
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
