config/configure.py -> configure?
Thu Jul 17 16:14:51 CDT 2008
On Jul 17, 2008, at 3:58 PM, Boyana Norris wrote:
> Speaking of configure and user experiences, I just noticed that
> PETSc defines top_builddir (in petscconf), which conflicts with
> automake-generated makefiles, making it impossible in some cases to
> include PETSc's petsconf file into Makefile.am (as far as I know
> that's the only thing that causes problems). I hate automake in
> general, but sometimes you are stuck with it and it's very nice to
> be able to include PETSc make snippets even in automake files and
> avoid a lot of pain.
> Anyway, since this is in a file that gets copied to the install
> location, I think in general it would be best to avoid defining
> build tree-related variables (especially those that conflict with
> auto-generated ones from other tools). Thoughts?
    I think this was originally in there when Matt was mucking around
with libtool (the gnu one, not the Mac one).
I don't think it is used and should be removed. Once Matt confirms
this, we will rip it out.
    Barry
> Boyana
> Satish Balay wrote:
>> On Thu, 17 Jul 2008, Satish Balay wrote:
>>>>  If we could support the same way that this is done with autoconf
>>>> packages
>>>> that would improve a users experience with PETSc.
>>> I guess we don't prevent the usage from shell scripts. We just
>>> promote
>>> the alternative usage of adding configure options in a python
>>> script.
>> And we generate $PETSC_ARCH/config/configure.py - which can be rerun
>> by the user. Alternative would be to generate this file in a
>> shell-script notation..
>> Satish
> Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
> Argonne National Laboratory          |   Phone: +1 (630) 252 7908 http://www.mcs.anl.gov/~norris/
>       |   Fax:   +1 (630) 252 5986
