docs for MINRES, only for positive definite?
Lisandro Dalcin dalcinl at gmail.com
Thu Feb 28 11:25:25 CST 2008
Good point, the current code seems to require that...
  ierr = KSP_PCApply(ksp,R,Z);CHKERRQ(ierr); /*     z  <- B*r       */
  ierr = VecDot(R,Z,&dp);CHKERRQ(ierr);
  if (dp < 0.0) {
    ksp->reason = KSP_DIVERGED_INDEFINITE_PC;
    PetscFunctionReturn(0);
Indeed, the following (simple minded, diagonal matrix) test fails with
-pc_type jacobi, but success with -pc_type none
import sys, petsc4py
petsc4py.init(sys.argv)
from petsc4py import PETSc
import numpy as N
A = PETSc.Mat().createAIJ([10,10])
for i in range(0,5):
    A[i,i] = -(i + 1)
for i in range(5,10):
    A[i,i] = +(i + 1)
A.assemble()
A.view()
x, b= A.getVecs()
b.set(1)
ksp = PETSc.KSP().create()
ksp.type = 'minres'
ksp.setOperators(A)
ksp.setFromOptions()
ksp.solve(b,x)
On 2/28/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     But does it require a positive definite preconditioner?
>     Barry
>  On Feb 28, 2008, at 9:32 AM, Matthew Knepley wrote:
>  > Docs are wrong.
>  >  Matt
>  > 2008/2/28 Lisandro Dalcin <dalcinl at gmail.com>:
>  >> I've noticed that the docs for MINRES say that the operator and the
>  >> preconditioner must be POSITIVE DEFINITE. But I understand MINRES is
>  >> tailored for the symmetric/hermitian-indefinite case.
>  >> Are the docs wrong? Or the actual code is a (very peculiar) MINRES
>  >> variant?
>  >> Lisandro Dalcín
>  >> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>  >> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>  >> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>  >> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>  >> Tel/Fax: +54-(0)342-451.1594
>  > What most experimenters take for granted before they begin their
>  > experiments is infinitely more interesting than any results to which
>  > their experiments lead.
>  > -- Norbert Wiener
Lisandro Dalcín
