MatConvert with same+reuse+inplace
Lisandro Dalcin dalcinl at gmail.com
Tue Feb 5 12:49:41 CST 2008
What is the expected behavior of the following, assuming option
'-matconvert_type' is not given?
MatConvert(A, MATSAME, MAT_REUSE_MATRIX, &A)
Should it be a no-op? I have to ask because if that is the case, It
seems the current code is broken. I'm missing something?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
