blocked index sets
Lisandro Dalcin dalcinl at gmail.com
Wed Aug 27 12:21:04 CDT 2008
On Wed, Aug 27, 2008 at 2:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 27, 2008 at 12:06 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> So, Do all us agree my proposed fix should be pushed? I'll wait for
>> Matt comments/complaints...
> I complain that IS is a fake parallel object.
> However, if
> GetSize/GetLocalSize already
> do this, then yes we should change the ISBlock version as well.
OK, I'll then push a fix ASAP.
>   Matt
>> On Wed, Aug 27, 2008 at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Aug 27, 2008, at 10:23 AM, Matthew Knepley wrote:
>>>> There is no concept of global for IS. They are purely serial. AO is the
>>>> only
>>>> global construct with indices.
>>>   This is kind of true, and maybe used to be completely true. But IS does
>>> have a communicator and that communicator can be MPI_COMM_WORLD or
>>> any parallel communicator.  In other words the IS is evolving to be an
>>> object
>>> that can be parallel in the same sense as vecs or mats
>>>   There are already ISGetSize() and ISGetLocalSize() so it sure makes sense
>>> to have the same paradgm for the ISGetBlockSize().
>>>   Barry
>>> Originally IS had no parallel concept, then we added the ISGetSize/LocalSize
>>> but forgot to do it for the ISBlock...
>>>>  Matt
>>>> On Wed, Aug 27, 2008 at 10:09 AM, Lisandro Dalcin <dalcinl at gmail.com>
>>>> wrote:
>>>>> I believe we have to review the interface of ISBlock. Currently,
>>>>> ISBlockGetSize() return the number of LOCAL block indices. This is not
>>>>> consistent with other naming conventions for getting local and glocal
>>>>> sizes. I propose to change this to the following
>>>>> 1) change: ISBlockGetSize() returns the number global blocks
>>>>> 2) addition:  ISBlockGetLocalSize() return the number of local blocks
>>>>> Comments?
>>>>> Lisandro Dalcín
>>>>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>>>>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>> Tel/Fax: +54-(0)342-451.1594
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>> Lisandro Dalcín
> -- Norbert Wiener
Lisandro Dalcín
