[petsc4py] What should be the 'default' communicator?
Lisandro Dalcin dalcinl at gmail.com
Tue Aug 26 08:20:23 CDT 2008
On Tue, Aug 26, 2008 at 12:36 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 25, 2008 at 8:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Can you  not overload the assignment = to automatically call whatever
>> fancy setter you want to use? Then you get the simplicity I crave and the
>> safety you desire?
> Yes, you can make it a 'property'.
No, No. 'property' works with instances of some class, but not with
modules. This is a feature I miss from Python. You cannot 'hook' on
attribute assignments in modules.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
