[petsc4py] What should be the 'default' communicator?
Mon Aug 25 20:13:49 CDT 2008
On Aug 25, 2008, at 5:40 PM, Lisandro Dalcin wrote:
> On Mon, Aug 25, 2008 at 6:48 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>  This is fine for me, except I vote against the setter/getter. Just
>> let the
>> power user access the variable PETSC_COMM_DEFAULT directly.
> Barry, sorry, I do not completely understand your comments. All my
> concern about this is only relevant to petsc4py and not core PETSc.
> With that in mind, I prefer to "hide" PETSC_COMM_DEFAULT from users,
> and ask them to call the getter/setter routines. You know: in Python,
> changing module-level globals is a bit unsafe: a user could do:
> from petsc4py import PETSc
> PETSc.COMM_DEFAULT = None # or watever
> and then latter get a failure. Furthermore, the setter can be in
> charge of all the relevant error checking: the comm have to actually
> be an instance of 'PETSc.Comm' type, and its comunicator cannot be the
> MPI_COMM_NULL.
    Can you  not overload the assignment = to automatically call
whatever
fancy setter you want to use? Then you get the simplicity I crave and
the
safety you desire?
    Barry
>> On Aug 25, 2008, at 4:43 PM, Lisandro Dalcin wrote:
>>> On Mon, Aug 25, 2008 at 6:22 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> I agree that people will do this, I just don't agree that it
>>>> should be
>>>> the default.
>>> Would you agree with the following:
>>> At petsc4py initialization (and after calling PetscInitialize()), I
>>> define PETSC_COMM_DEFAULT = PETSC_COMM_WORLD. All parallel PETSc
>>> objects created through petsc4py use PETSC_COMM_DEFAULT if the
>>> communicator is not explicitelly passed as an argument.
>>> Additionally,
>>> I expose in petsc4py a getter/setter enabling users to change at ANY
>>> TIME the default communicator to use. With this approach, the world
>>> communicator will be default, unless changed by the (power) user.
>>>>> To be honest, I've never looked too much at paradigms like
>>>>> Condor. But
>>>>> using them implies to learn yet another framework. Another
>>>>> anecdote: a
>>>>> guy sent me a mail with questions about mpi4py for solving a
>>>>> embarassingly parallel problems. I asked why he was trying to
>>>>> use such
>>>>> a "heavy weight" approach. And then he answered he was tired of
>>>>> the
>>>>> complications and performance of using a Grid-based approach,
>>>>> and that
>>>>> 'mpiexec' a Python script with some coordinating MPI calls was far
>>>>> easier to setup, extend, and maintain and had better overall
>>>>> running
>>>>> times than submitting jobs to "The Grid".
>>>> That is my experience with grid software as well. However, in the
>>>> particular case
>>>> of Condor, I disagree. It is fairly easy to setup and has great
>>>> features like fault
>>>> tolerance, automatic migration and balancing, that make it much
>>>> more
>>>> useful
>>>> that just MPI.
>>>> Matt
>>>>>> On Mon, Aug 25, 2008 at 10:54 AM, Lisandro Dalcin <dalcinl at gmail.com
>>>>>> wrote:
>>>>>>> After working hard on mpi4py, this week I'll spend my time
>>>>>>> cleaning-up
>>>>>>> and adding features to the new Cython-based petsc4py. Then,
>>>>>>> I'll be
>>>>>>> asking questions to this list requesting for advise.
>>>>>>> In all calls that create new PETSc objects, I've decided to
>>>>>>> make the
>>>>>>> 'comm' argument optional. If the communicator is not passed,
>>>>>>> PETSC_COMM_WORLD is currently used. This is the approach PETSc
>>>>>>> uses in
>>>>>>> some C++ calls implemented through PetscPolymorphicFunction().
>>>>>>> But now I believe that is wrong, and that PETSC_COMM_SELF
>>>>>>> should be
>>>>>>> the default. Or perhaps even better, I should let users set the
>>>>>>> default communicator used by petsc4py to create new (parallel)
>>>>>>> objects.
>>>>>>> An anecdote: some time ago, a petsc4py user wrote a sequential
>>>>>>> code
>>>>>>> and created objects without passing communicator arguments,
>>>>>>> next he
>>>>>>> wanted to solve many of those problems in different worker
>>>>>>> processes
>>>>>>> in a "ambarrasingly parallel" fashion and collect results at the
>>>>>>> master process. Of course, he run into trouble. Then I asked
>>>>>>> him to
>>>>>>> initialize PETSc in such a way that PETSC_COMM_WORLD was
>>>>>>> actually
>>>>>>> PETSC_COMM_SELF (by setting the world comm before
>>>>>>> PetscInitalize()).
>>>>>>> This mostly works, but has a problem: we have lost the actual
>>>>>>> PETSC_COMM_WORLD, so we are not able to create a parallel
>>>>>>> object after
>>>>>>> PetscInitialize().
>>>>>>> Any thoughts?
>>>>>>> Lisandro Dalcín
>>>>>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>>>>>> (CIMEC)
>>>>>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>>>>>> (INTEC)
>>>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas
>>>>>>> (CONICET)
>>>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>>>> Tel/Fax: +54-(0)342-451.1594
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to
>>>>>> which
>>>>>> their experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Lisandro Dalcín
>>>>> (CIMEC)
>>>>> (INTEC)
>>>>> (CONICET)
>>>> which
>>>> -- Norbert Wiener
>>> Lisandro Dalcín
>>> (CIMEC)
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
