[petsc4py] What should be the 'default' communicator?
Mon Aug 25 16:48:09 CDT 2008
    This is fine for me, except I vote against the setter/getter. Just
let the
power user access the variable PETSC_COMM_DEFAULT directly.
    Barry
On Aug 25, 2008, at 4:43 PM, Lisandro Dalcin wrote:
> On Mon, Aug 25, 2008 at 6:22 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> I agree that people will do this, I just don't agree that it should
>> be
>> the default.
> Would you agree with the following:
> At petsc4py initialization (and after calling PetscInitialize()), I
> define PETSC_COMM_DEFAULT = PETSC_COMM_WORLD. All parallel PETSc
> objects created through petsc4py use PETSC_COMM_DEFAULT if the
> communicator is not explicitelly passed as an argument. Additionally,
> I expose in petsc4py a getter/setter enabling users to change at ANY
> TIME the default communicator to use. With this approach, the world
> communicator will be default, unless changed by the (power) user.
>>> To be honest, I've never looked too much at paradigms like Condor.
>>> But
>>> using them implies to learn yet another framework. Another
>>> anecdote: a
>>> guy sent me a mail with questions about mpi4py for solving a
>>> embarassingly parallel problems. I asked why he was trying to use
>>> such
>>> a "heavy weight" approach. And then he answered he was tired of the
>>> complications and performance of using a Grid-based approach, and
>>> that
>>> 'mpiexec' a Python script with some coordinating MPI calls was far
>>> easier to setup, extend, and maintain and had better overall running
>>> times than submitting jobs to "The Grid".
>> That is my experience with grid software as well. However, in the
>> particular case
>> of Condor, I disagree. It is fairly easy to setup and has great
>> features like fault
>> tolerance, automatic migration and balancing, that make it much
>> more useful
>> that just MPI.
>>  Matt
>>>> On Mon, Aug 25, 2008 at 10:54 AM, Lisandro Dalcin <dalcinl at gmail.com
>>>> > wrote:
>>>>> After working hard on mpi4py, this week I'll spend my time
>>>>> cleaning-up
>>>>> and adding features to the new Cython-based petsc4py. Then, I'll
>>>>> be
>>>>> asking questions to this list requesting for advise.
>>>>> In all calls that create new PETSc objects, I've decided to make
>>>>> the
>>>>> 'comm' argument optional. If the communicator is not passed,
>>>>> PETSC_COMM_WORLD is currently used. This is the approach PETSc
>>>>> uses in
>>>>> some C++ calls implemented through PetscPolymorphicFunction().
>>>>> But now I believe that is wrong, and that PETSC_COMM_SELF should
>>>>> be
>>>>> the default. Or perhaps even better, I should let users set the
>>>>> default communicator used by petsc4py to create new (parallel)
>>>>> objects.
>>>>> An anecdote: some time ago, a petsc4py user wrote a sequential
>>>>> code
>>>>> and created objects without passing communicator arguments, next
>>>>> he
>>>>> wanted to solve many of those problems in different worker
>>>>> processes
>>>>> in a "ambarrasingly parallel" fashion and collect results at the
>>>>> master process. Of course, he run into trouble. Then I asked him
>>>>> to
>>>>> initialize PETSc in such a way that PETSC_COMM_WORLD was actually
>>>>> PETSC_COMM_SELF (by setting the world comm before
>>>>> PetscInitalize()).
>>>>> This mostly works, but has a problem: we have lost the actual
>>>>> PETSC_COMM_WORLD, so we are not able to create a parallel object
>>>>> after
>>>>> PetscInitialize().
>>>>> Any thoughts?
>>>>> Lisandro Dalcín
>>>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>>>> (CIMEC)
>>>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>>>> (INTEC)
>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas
>>>>> (CONICET)
>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>> Tel/Fax: +54-(0)342-451.1594
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to
>>>> which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>>> Lisandro Dalcín
>>> (CIMEC)
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
