New approach for external direct solvers in PETSc
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 11 11:40:36 CDT 2008
Mat in PETSc is actually a short hand notation for "Linear
transformation"
http://en.wikipedia.org/wiki/Linear_transformation. Essentially the only
operation defined by a linear transformation is A*x. Matrices are
simply one
way of representing finite dimensional linear transformations. So a
Mat is suppose to ALWAYS provide a MatMult() everything else is
optional :-).
Now you can certainly say that we should have called linear
transformations
in PETSc something like: LT or LinearTrans or many other things. We
chose
Mat since almost everyone understands linear transformations as
matrices so
we do not need to provide a high-falutin explanation of LT that would
simply
alienate and scare most potential users. Everyone thinks they understand
Mat immediately.
Now back to the issue at hand. You had a very valid point in the
previous
email: for a factored matrix if we define MatMult() as the triangular
solves
then the factored matrix defines a linear transformation (whose
representation
is not simply a two dimensional array, but is slightly more
complicated beast).
So we could define a MATFACTOR as a new Mat object, like MatMFFD is
a Mat object and then subclass the various packages factors undernether
it.
Barry
On Aug 11, 2008, at 9:11 AM, Lisandro Dalcin wrote:
> On Fri, Aug 8, 2008 at 2:01 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> This is just at hack to avoid so many changes in PETSc.
>> MatMFFD is truly a matrix (it has matrix vector product).
> Well, I'm not so sure about that. Do it has MatSetValues() ?
>> Barry
>> On Aug 8, 2008, at 8:23 AM, Lisandro Dalcin wrote:
>>> Barry, after thinking a bit more, I believe I've found an approach
>>> that is not so radical.
>>> Why not to follow the approach for MatMFFD? That is, introduce a new
>>> matrix type, instead of a brand new object type. Let me call this
>>> new
>>> matrix type MATFACTOR. This new matrix type contains a hidden
>>> PetscObject, and that object is filled with appropriate methods
>>> depending on the MatSolverPackage.
>>> This new way will not introduce a new object type in the user-level
>>> API. An I believe that we will still simplify the code. Now a
>>> MatSolve
>>> in a MATSEQAIJ matrix will fail just because it will not have the
>>> operation filled in the 'virtual table'. MATFACTOR will fill the
>>> MatXXXFactor{Symbolic/Numeric} options in the vtable, but it will
>>> not
>>> fill things like MatMult and MatSetValues. This way, we will not
>>> need
>>> any more to 'check' if a standard matrix type like SEQAIJ, MPIAIJ,
>>> etc
>>> are or are not factored (and perhaps we can handle dense matrices
>>> in a
>>> special way, just because inplace factorizations do really make
>>> sense). So the all the 'mat->factor' checks can finally go away!
>>> What do you think?
>>> On Thu, Aug 7, 2008 at 5:05 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> On Jul 25, 2008, at 5:47 PM, Lisandro Dalcin wrote:
>>>>> BTW, Have you ever considered the posibility of not using the
>>>>> 'Mat'
>>>>> class for factored matrices?? I believe that normal matrices and
>>>>> factored matrices share very few in common as to being instances
>>>>> of
>>>>> the same class. Looking at the source code in src/mat, there are
>>>>> many
>>>>> checks like 'if (mat-->factor)' or 'if (!mat->factor)' that
>>>>> seems to
>>>>> support my concern. What do you think?
>>>> After a (tiny) bit more thought I think we really should make this
>>>> change:
>>>> pros
>>>> 1) it will simplify the code a good amount hence less bugs
>>>> 2) conceptually it makes sense
>>>> cons
>>>> 1) requires a large reorganization of the Mat code (will
>>>> introduce bugs)
>>>> 2) requires the user to deal with one more PETSc object (MatFactor)
>>>> But since most users deal with SNES/KSP/PC most users will
>>>> never see this new object.
>>>> The question is when/how to make this massive change. It is as big
>>>> or bigger than the change I already made with MatGetFactor().
>>>> Barry
>>>>> On Fri, Jul 25, 2008 at 7:02 PM, Barry Smith
>>>>> <bsmith at mcs.anl.gov> wrote:
>>>>>> petsc-dev users,
>>>>>> I have finally completed my changes to PETSc for a new approach
>>>>>> to
>>>>>> accessing external direct solvers
>>>>>> in PETSc like Spooles, MUMPS etc. I will be pushing it to petsc-
>>>>>> dev
>>>>>> sometime
>>>>>> the middle of next week.
>>>>>> If you are using the direct solvers you might consider cloning
>>>>>> from
>>>>>> http://petsc.cs.iit.edu/hg/petsc/petsc-dev-new-solvers or
>>>>>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev-new-solvers
>>>>>> and trying it out before then. Please report problem to
>>>>>> petsc-maint at mcs.anl.gov as you hit them.
>>>>>> Barry
>>>>>> From the changes file
>>>>>> The "parallel direct solver" matrix types like
>>>>>> MATAIJSPOOLES are ALL gone. Now you use -
>>>>>> pc_factor_mat_solver_package
>>>>>> spooles etc or PCFactorSetMatSolverPackage() or if working
>>>>>> directly
>>>>>> with
>>>>>> matrices, MatGetFactor(A,MATSPOOLES,...)
>>>>> Lisandro Dalcín
>>>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>>>> (CIMEC)
>>>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>>>> (INTEC)
>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas
>>>>> (CONICET)
>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>> Tel/Fax: +54-(0)342-451.1594
>>> Lisandro Dalcín
>>> (CIMEC)
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
