Problem with VecPlaceArray_MPI & VecResetArray
Fri Aug 8 21:16:27 CDT 2008
    I've pushed the fix. If you recompile in src/vec/vec/impls/mpi it
should go through.
    Please let us know if you still have problems,
    Barry
On Aug 8, 2008, at 4:03 PM, Eric Chamberland wrote:
> Hi,
> I try to use the VecPlaceArray/VecResetArray functions.
> Unfortunately, the call to VecPlaceArray only work the firsdt time I
> do it, even if I call VecResetArray before the next call...
> the code looks like this:
> VecPlaceArray(vec, myvec);
> VecResetArray(vec);
> VecPlaceArray(vec, myvec2);  /* PETSCERROR ON THIS LINE*/
> The error I get is the following (from src/vec/vec/impls/seq/dvec2.c:
> 975):
>  if (v->unplacedarray)
> SETERRQ(PETSC_ERR_ARG_WRONGSTATE,"VecPlaceArray() was already called
> on this vector, without a call to VecResetArray()");
> After looking at the code, I found that MPI vectors where defining a
> VecPlaceArray_MPI which call VecPlaceArray on the "child" v-
> >localrep (ref: src/vec/vec/impls/mpi/pbvec.c:79), but I haven't
> found an "overload" of VecResetArray that would do the same work.
> Is that the problem?
> I am using PETSc 2.3.3-p6.
> Thanks,
> Eric
