Is c2html a required external package?
Fri Aug 8 20:49:11 CDT 2008
    Please send us what you did so everyone can benefit from your fix.
    Barry
On Aug 8, 2008, at 8:05 PM, Shi Jin wrote:
> I managed to build a working c2html with playing with the compilers.
> However, I do think it is a bug when --with-c2html=0 is set while it
> is still required.
> Shi
> Shi Jin, PhD
> ----- Original Message ----
>> From: Barry Smith <bsmith at mcs.anl.gov>
>> To: petsc-dev at mcs.anl.gov
>> Sent: Friday, August 8, 2008 11:58:02 AM
>> Subject: Re: Is c2html a required external package?
>>   If IBM compilers cannot compile c2html then they are buggy. c2html
>> is simple straightforward C code.
>> Let's see what is going wrong.
>>    Barry
>> On Aug 8, 2008, at 8:49 AM, Satish Balay wrote:
>>> I suspect c2html does not compile with IBM compilers. We should
>>> support --with-c2html=0 option.
>>> Satish
>>> On Fri, 8 Aug 2008, Matthew Knepley wrote:
>>>> On Fri, Aug 8, 2008 at 12:09 AM, Shi Jin
>>>> wrote:
>>>>> Hi there,
>>>>> I was trying to build petsc-dev on a IBM AIX but failed at c2html.
>>>>> I tried not to use it with --with-c2html=0 but it seemed still be
>>>>> needed. Why do we need it? I don't need to generate documentations
>>>>> for this test.
>>>>> Thanks.
>>>> It is for documentation, but we do not consider an installation
>>>> with
>>>> broken documentation fully functional. Can you send
>>>> the configure.log?
>>>> Thanks,
>>>>    Matt
>>>>> Shi
>>>>> Shi Jin, PhD
