first comments after reviewing and trying the new matrix factorization code
Lisandro Dalcin dalcinl at gmail.com
Thu Aug 7 14:24:14 CDT 2008
I've started to wrap the functionality of the new code in petsc4py.
However, I'm detecting some inconsistencies and possible
improvements/simplifications and then I need some directions in order
to push good fixes in petsc-dev.
Then, here is my tow first questions.
1) Suppose I do
MatGetFactor(A, solver_package, factor_type, &F)
Then, if the call is successful, the following should happen
a) F->factor should be equal to 'factor_type'
b) F->preallocated sould be PETSC_TRUE
c) F->assembled sould be PETSC_TRUE
Is this OK?
2) What should be the output of MatView(F, viewer) ?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
