Compiling PETSc with Visual Studio 2008
Farshid Mossaiby mossaiby at yahoo.com
Wed Apr 23 10:19:17 CDT 2008
I built PETSc with this command line after installing
latest MPICH2:
./config/configure.py --with-cc='win32fe cl
--nodetect' --with-fc=0 --with-ar='win32fe lib
--nodetect' PETSC_ARCH=cygwin-c-debug-mpi --with-mpi=1
--with-mpi-dir=/cygdrive/c/Program\ Files/MPICH2/
--download-c-blas-lapack=../f2cblaslapack.tar.gz
It compiles OK but stops after "make all test":
Completed building libraries
Shared libraries disabled
Running test examples to verify correct installation
... and I have to press Ctrl-C to quit. Have I done
anything wrong?
Farshid Mossaiby
--- Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 23 Apr 2008, Farshid Mossaiby wrote:
> > Dear Satish,
> > Thanks for all your helpful comments.
> > I am currently doing a 32 bit build. I will try to
> > install MPICH2 binaries and report the results.
> > I read a bit the manual of latest MPICH2; it says
> you
> > can build it very easily under windows. I still
> cannot
> > understand why Matt wrote:
> > MPICH (and any other MPI) does not build
> automatically
> > on Windows. You have to download binaries, which
> means
> > you are stuck with whatever compilers were used to
> > build it.
> PETSc configure cannot build it with the option
> --download-mpich=1 [or
> the alternate mpi with --download-lam=1]. If you
> know how to build it
> yourself, and then configure PETSc with it - then
> that should work.
> No one has attempted this on windows yet [as far as
> I know].
> Why would you prefer to build MPICH from sources on
> windows - when the
> binary install is available?
> Satish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
