sshfs
Ethan Coon etc2103 at columbia.edu
Thu Apr 3 08:39:09 CDT 2008
hey Aron,
Is there a good (preferably non-fink) version of sshfs/fuse for mac?  I
saw a few options... MacFuse, http://www.pqrs.org/tekezo/macosx/sshfs/
etc
any thoughts?
ethan
On Mon, 2008-03-17 at 11:27 -0400, Aron Ahmadia wrote:
> Can the namespace issue be fixed with some macro magic?
> #ifdef UNIQUE_PETSC_NAMESPACE
> #define Mat PetscMat
> #endif
> #undef Mat
> This seems like it would satisfy both parties, and a compiler/build
> flag could uniqueify the namespace if needed.
> ~A
> On Mon, Mar 17, 2008 at 11:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Sun, Mar 16, 2008 at 7:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  >      There are two significant  changes I'd like to see before the
> >  >  next PETSc release:
> >  >  1) remove the overly complicated (from a user perspective) matrix
> >  >  subclassing for the various external
> >  >       matrix solver packages and replace with MatSolverSetType() -
> >  >  mat_solver_type <type> that simply
> >  >       flips the various factorization/solver functions with those
> >  >  requested and
> >  This seems not too hard. Just a layer on top to run the code a user must
> >  run now.
> >  >  2) properly name-space PETSc by putting a Petsc in front of all PETSc
> >  >  objects, function names etc
> >  >       (this will require changing a few names also to keep them below
> >  >  the 32 character limit). This will
> >  >       be very painful change for some users who are not comfortable
> >  >  ever changing code, hence I hesitate
> >  >       to do it, but it is the right thing to do and should have been
> >  >  done originally.
> >  I guess I still do not see the need for this. NIMROD is a not a sufficient
> >  driver in my mind. If we really want namespaces, use a real language that
> >  has namespaces. There are plenty. If we are still using C, I say we stick
> >  with the old division. The imposition of this much pain on the overwhelming
> >  majority of users seems unjustified.
> >  Namespaces issues can be trivially fixed in say C++, which we should do.
> >     Matt
> >  >      Maybe we can do a release in around a couple of months, it would
> >  >  be 2.4
> >  >     Barry
> >  What most experimenters take for granted before they begin their
> >  experiments is infinitely more interesting than any results to which
> >  their experiments lead.
> >  -- Norbert Wiener
Ethan Coon
DOE CSGF - Graduate Student
Dept. Applied Physics & Applied Mathematics
Columbia University
212-854-0415
http://www.ldeo.columbia.edu/~ecoon/
