Release
Lisandro Dalcin dalcinl at gmail.com
Sat Sep 29 17:13:46 CDT 2007
Barry, please take a look at this thread in Python-Dev mailing list,
just the first and second mail.
http://mail.python.org/pipermail/python-dev/2003-July/036898.html
Python 2.X does exactly the same as PETSc for defining derived object
structures.
#define PyObject_HEAD			\
	_PyObject_HEAD_EXTRA		\
	Py_ssize_t ob_refcnt;		\
	struct _typeobject *ob_type;
typedef struct _object {
	PyObject_HEAD
} PyObject;
typedef struct {
    PyObject_HEAD
    double ob_fval;
} PyFloatObject;
But For Python 3.X, they will be using...
} PyObject;
#define PyObject_HEAD        PyObject ob_base;
typedef struct {
    PyObject_HEAD
    double ob_fval;
} PyFloatObject;
This is the way I'm trying to redefine PetscObject for PETSc.
On 9/29/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Well, I followed the approach in Python 3.0 for
> > defining the base object header for derived objects.
>   Lisandro,
>   Please send a reference to where this is discussed and an explanation
> why this type of caste is allowed with strict aliasing? (the web page
> http://www.cellperformance.com/mike_acton/2006/06/understanding_strict_aliasing.html
> does not discuss this case nor does it give any indication that this
> "trick" is legal with strict alaising).
>    Thanks
>     Barry
> On Wed, 26 Sep 2007, Lisandro Dalcin wrote:
> > On 9/25/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >     Please explain in detail.
> > Well, this article explains strict aliasing in some detail (just in
> > case you does not know the details)
> > In the particular case of PETSc, if I understand correctly, the
> > designed object's struct inheritance based in the current PETSCHEADER
> > approach will not make it possible to enable strict aliasing rules.
> > For the compiler, PetscObject and Vec are different types of objects,
> > so if you do
> > PetscObject o = (PetscObject)v;
> > you are breacking strict aliasing rules, using o->comm and v->comm to
> > access the vector communicator could possibly fail with aggresive
> > compiler optimization.
> > How to solve this?? Well, I followed the approach in Python 3.0 for
> > defining the base object header for derived objects. In the case of
> > PETSc, this amounts to the following:
> > #define PETSCHEADERBASE \
> >   PetscCookie    cookie;
> >   MPI_Comm       comm;
> >   char*                prefix;
> >   char*                type_name;
> >   /* etc ....*/
> > struct _p_PetscObject {
> >   PETSCHEADERBASE
> > #define PETSCHEADER(ObjectOps) \
> >   struct _p_PetscObject header;
> >   ObjectOps                   *ops;
> > And now the Vec struct is declared as before:
> > struct _p_Vec {
> >   PETSCHEADER(struct _VecOps);
> >   /* etc ... */
> > Now, there is no way to access things like cookie/comm/prefix fro a
> > Vec, for doing it you need to cast to PetscObject. This removes the
> > possibility of accesing 'comm' or 'prefix' though pointers of
> > different types. As a side effect, you need to always cast to
> > PetscObject to get comm/prefix/type_name (by far the more commonly
> > accessed members when implementing Vec/Mat/KSP etc...)
> > I'm started this work at home, I do not have the code here at my
> > office right now, but I could remove almost all the warnings related
> > to strict aliasing in 'src/sys' and 'src
> > > > I have also some problems when calling PetscObjectQueryFunction, >
> > >    Yes this function pointer casting stuff is a royal pain and ugly.
> > Perhaps I can find better way of doing this using a macro.
> > >   Might be easier to just rewrite everything in C++. :-)
> > Well, having error handling based on C++ exceptions is really
> > tempting. But C++ polymorphism would make it easier to derive specific
> > implementations of objects, and using smart pointer would help for the
> > automatic reference counting of owned objects, and a lot of more good
> > things. BUT... the PETSc way of doing polimorphism is a bit more
> > powerful than the C++ virtual table. That is, each object instance
> > have its own table of functions pointers, and you can freely replace
> > it in a object by object base (and done in some MatConvert() calls).
> > Of course, a C++ implementation could still use tables of function
> > pointer, and dispatching code based on that table.
> > All this would require a lot, lot of redesing and work. :)
> > BTW, Could you please teach me some easy way of replacing in PETSc
> > source code the following:
> > 'something>comm'    by   '((PetscObject)something)->comm'
> > I never found the time to learn regular expresions and 'sed'  :-(.
> > >   Barry
> > > > In case
> > > > you want me to continue this work, I will need a bit of help in a few
> > > > places related to low-level calls related to sockets and sys calls.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
