Release
Lisandro Dalcin dalcinl at gmail.com
Tue Sep 25 16:40:37 CDT 2007
On 9/22/07, Matthew Knepley <knepley at gmail.com> wrote:
> What do you think about 2.4 in October? I really want to get the new
> install out there.'
I'm experimenting at home about a way to compile petsc with
'-fstrict-aliasing', in order to follow C99 strict aliasing rules.
However, If I am right, this requiered a new layout for PetscObect's
structure (I basically followed the approach being used for Python
3.0). As a side effect, some very commonly used struct members (like
'comm', 'type_name', and 'prefix') have to be accessed by casting
derived objecs as PetscObject, i.e.:   Vec v;  ((PetscObject)v)->comm.
I have also some problems when calling PetscObjectQueryFunction, as
the compiler complains about strict aliasing rules, and I need to
define an additional function pointer, get the function, and next cast
to the a actual func. pointer to do the call. Not suure yet if this
can be improved, perhaps a macro can help.
Is there any interest in this be completed? It's a nonsense? In case
you want me to continue this work, I will need a bit of help in a few
places related to low-level calls related to sockets and sys calls.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
