request for advice cleaning up SNES
Lisandro Dalcin dalcinl at gmail.com
Mon Sep 3 15:59:32 CDT 2007
On 9/3/07, Matthew Knepley <knepley at gmail.com> wrote:
> On 9/3/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > In de process of cleaning up SNES, I am not sure about the management
> > of afine (rhs) vector.
> I think it should be destroyed.
I think the same. I think I'll do that.
> > BTW, I believe in the past you had and next removed
> > KSPSetRhs()/KSPSetSolution() . Should this approach be also followed
> > in SNES?
> Not sure. Why are these there?
I do not know. If you grep in petsc-dev,
SNESSetRhs()/SNESSetSolution() are not used in any place other than
SNES interface.
Do you think we can get rid of these two funtions and follow the
behavior of KSP?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
