request for advice cleaning up SNES
Lisandro Dalcin dalcinl at gmail.com
Mon Sep 3 15:29:04 CDT 2007
In de process of cleaning up SNES, I am not sure about the management
of afine (rhs) vector. So the question is:
If the user call:
SNESSolve(PETSC_NULL, x)
should any previously set (VecSetRhs) afine vector be destroyed/zeroed
or should it not be touched in any way?
BTW, I believe in the past you had and next removed
KSPSetRhs()/KSPSetSolution() . Should this approach be also followed
in SNES? IMHO, the final interface would be simpler and less
error-prone.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
