changing MatSetUp()
Lisandro Dalcin dalcinl at gmail.com
Tue Oct 23 15:56:14 CDT 2007
I completelly agree, I never liked that XXXSetFromOptions() calls
inside XXXSetUp().
So I will change VecSetUp() and MatSetUp() to set a default type if it
was not set, and next call MatSetUpPreallocation() for matrices.
On 10/23/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   This is a valid point. I have to agree with Matt
>  In KSPSetUp() we have
>   if (!((PetscObject)ksp)->type_name){
>     ierr = KSPSetType(ksp,KSPGMRES);CHKERRQ(ierr);
>   In PCSetUp() we have
>   if (!((PetscObject)pc)->type_name) {
>     ierr = PCGetDefaultType_Private(pc,&def);CHKERRQ(ierr);
>     ierr = PCSetType(pc,def);CHKERRQ(ierr);
>   In SNESSetUp() we have
>   if (!((PetscObject)snes)->type_name) {
>     ierr = SNESSetType(snes,SNESLS);CHKERRQ(ierr);
>    BUT in VecSetUp() we again have the "illegal"
>   ierr = VecSetFromOptions(v);CHKERRQ(ierr);
>   I think we should have MatSetUp() and VecSetUp()
> behave like the others and set a default one if it is
> not already set; and NOT call SetFromOptions.
>    Barry
> On Tue, 23 Oct 2007, Matthew Knepley wrote:
> > I am not sure about this. MatSetFromOptions() is intentionally optional,
> > and should not be bundled in a method not intended to be optional.
> >   Matt
> > On 10/23/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > > After greping, it seems that MatSetUp() is not used in all 'petsc-dev'
> > > repo. If there is no objections (Barry?), I will change it (by
> > > reverting inner calls order) to do the following:
> > > PetscErrorCode MatSetUp(Mat A)
> > >   MatSetFromOptions(A);
> > >   MatSetUpPreallocation(A);
> > > As I mailed some time ago, there is no point of calling
> > > MatSetUpPreallocation() if the matrix type was not set.
> > > Lisandro Dalcín
> > > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > > Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
