Compiling on Solaris 10 for X86
Yi-Feng Adam Zhang Adam.Zhang at Sun.COM
Thu May 10 21:40:12 CDT 2007
Hi Matt,
I am a Software Engineer, working for Sun Microsystems. My team is
called Open Source Team. Our intend or goal is to make some significant
invest on Open Source Community to support them to make their software
or solution available on Solaris and Sun Grid. Both of them are open
sourced now: www.opensolaris.org, https://sungrid.dev.java.net/ and
http://gridengine.sunsource.net/
PETSc is a well known with high-profile community in Scientific
Computing area. I'd like to port PETSc to Solaris OS 10 for X86 Platform
and make it available on Sun Grid Compute Utility which is available
from http://www.network.com . If everything is OK both on technical side
and license side, I'd like to release a Solaris Package on the Internet,
Maybe PETSc website, https://sungrid.dev.java.net/ or other 3rd party
website. So the developers including Solaris developers or Sun Grid
Developers can use or adopt the PETSc with a already-built Solaris Package.
BTW, I find I can't subscribe or use another alias:
petsc-maint at mcs.anl.gov which is mainly for installation & compilation
questioning. Is this alias still working?
Adam
Matthew Knepley wrote:
> On 5/10/07, Adam Zhang <Adam.Zhang at sun.com> wrote:
>> Thank you for input. I will try to use gmake later.
>> If this compilation is ok. can I release this as a Solaris package on
>> the internet?
> I guess. What is it for?
>  Thanks,
>    Matt
>> Regards,
>> Adam
>> > Nothing is wrong with the PETSc build or libraries. However, your make
>> > (probably not gmake) has a problem with the make rule that cleans up
>> > files
>> > in bmake/common/rules:359. You can just ignore it (or tell us what is
>> > wrong).
>> >  Thanks,
>> >     Matt
>> > On 5/10/07, Yi-Feng Adam Zhang <Adam.Zhang at sun.com> wrote:
>> >> Hi all,
>> >> Recently I am compiling the PETSc 2.3.2 -P10 on Solaris 10 for X86
>> with
>> >> GCC and Sun's f90.
>> >> Here is the command I give to configure.py:
>> >> ./config/configure.py --download-f-blas-lapack=1 --with-mpi=0
>> >> Yes. I don't use the MPI intendedly.  Because I want to make sure
>> every
>> >> thing is ok before using MPI.
>> >> When I input the command "make all", every  thing looks fine.
>> >> But when I try to use "make test" to verify, I get the following
>> error:
>> >> -bash-3.00# more test_log_solaris2.10-c-debug
>> >> Running test examples to verify correct installation
>> >> C/C++ example src/snes/examples/tutorials/ex19 run successfully
>> with 1
>> >> MPI process
>> >> Graphics example src/snes/examples/tutorials/ex19 run successfully
>> with
>> >> 1 MPI process
>> >> sh: test: argument expected
>> >> *** Error code 1 (ignored)
>> >> The following command caused the error:
>> >> if test -e ex19.exe; then /usr/bin/rm -f ex19.exe; fi
>> >> if test -e ex19.ilk; then /usr/bin/rm -f ex19.ilk; fi
>> >> if test -e ex19.pdb; then /usr/bin/rm -f ex19.pdb; fi
>> >> if test -e ex19.tds; then /usr/bin/rm -f ex19.tds; fi
>> >> Fortran example src/snes/examples/tutorials/ex5f run successfully
>> with 1
>> >> MPI process
>> >> if test -e ex5f.exe; then /usr/bin/rm -f ex5f.exe; fi
>> >> if test -e ex5f.ilk; then /usr/bin/rm -f ex5f.ilk; fi
>> >> if test -e ex5f.pdb; then /usr/bin/rm -f ex5f.pdb; fi
>> >> if test -e ex5f.tds; then /usr/bin/rm -f ex5f.tds; fi
>> >> Completed test examples
>> >> Does anyone have any suggestion?  Thanks in advance!
>> >> Regards,
>> >> Adam
