changes to PETSc-dev bmake system and library locations
Todd Munson tmunson at mcs.anl.gov
Mon Jun 11 09:23:39 CDT 2007
I had configured and built petsc-dev prior to updating to the new
configuration system.  That did not work...once the update happens
things get screwed up and nothing in the build system works.  Maybe the
BuildSystem module was old, but I would figure that it should get updated
when you check for its existence...
Anyway, I cloned a new copy of petsc-dev and everything now builds...
Cheers, Todd.
On Mon, 11 Jun 2007, Matthew Knepley wrote:
> Maybe you have an old BuildSystem?
>   Matt
> On 6/11/07, Todd Munson <tmunson at mcs.anl.gov> wrote:
> > I just downloaded the new updates and tried configuring the development
> > version and get the following python errors...It may be a problem on my
> > side.  I'll try with a new clone of the repository...
> > akita % ./config/configure.py --with-c++
> > Configuring PETSc to compile on your system
> > UNABLE to FIND MODULE for config/configure.py
> > No module named Fiat
> >   File "./config/configure.py", line 175, in petsc_configure
> >     framework =
> > config.framework.Framework(sys.argv[1:]+['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions'],
> > loadArgDB = 0)
> >   File
> > "/sandbox/tmunson/projects/petsc-dev/python/BuildSystem/config/framework.py",
> > line 91, in __init__
> >     self.createChildren()
> >   File
> > line 317, in createChildren
> >     self.getChild(moduleName)
> >   File
> > line 302, in getChild
> >     config.setupDependencies(self)
> >   File "/sandbox/tmunson/projects/petsc-dev/python/PETSc/Configure.py",
> > line 44, in setupDependencies
> >     utilityObj              =
> > self.framework.require('PETSc.'+d+'.'+utilityName, self)
> >   File
> > line 322, in require
> >     config = self.getChild(moduleName, keywordArgs)
> >   File
> >   File "/sandbox/tmunson/projects/petsc-dev/python/PETSc/packages/FFC.py",
> > line 11, in setupDependencies
> >     self.fiat = self.framework.require('config.packages.Fiat', self)
> >   File
> >   File
> > line 275, in getChild
> >     type   = __import__(moduleName, globals(), locals(),
> > ['Configure']).Configureakita %
> > Todd Munson                      (630) 252-4279  office
> > Argonne National Laboratory      (630) 252-5986  fax
> > 9700 S. Cass Ave.                tmunson at mcs.anl.gov
> > Argonne, IL 60439                http://www.mcs.anl.gov/~tmunson
> > On Sun, 10 Jun 2007, Barry Smith wrote:
> > > On Sun, 10 Jun 2007, Matthew Knepley wrote:
> > > > This is very vague concerning the structure of exernalpackages. I cannot tell
> > > > where libraries are supposed to end up, and how/when/why they might be moved.
> > >   They end up in
> > >    $PETSC_ARCH/lib (same place as PETSc libraries, without a make install) and
> > >    prefix/lib  (with a make install)
> > > > It seems that the directory information coming from PETSc/package.py
> > > > has also changed.
> > >    Yes. package.py had a /lib hardwired to the end of the install directory
> > > returned by the particular package. Now the particular packages set the
> > > entire path where the library goes (that is a /lib is not automatically
> > > appended).
> > >    Barry
> > > >   Matt
> > > > On 6/8/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > >   PETSc-dev users,
> > > > >     After picking Satish's brain, I have made a set of changes to
> > > > > petsc-dev related to compiling and linking programs.
> > > > >    Goal:  Support the GNU; config/configure.py; make; make install model
> > > > > including all external packages PETSc builds for you. After "make install"
> > > > > PETSC_ARCH should not be needed.
> > > > >    Constraints:
> > > > > * Allow skipping the "make install" step and yet having everything
> > > > > fully functional even with shared and dynamic libraries
> > > > > * Allow multiple builds in the non-"make install" approach which you can
> > > > > switch between by changing PETSC_ARCH
> > > > > * Not require any file links
> > > > > * A system that does not mix generated files and non-generated in the same
> > > > > directory in $PETSC_DIR
> > > > > * A system no more complicated then the previous version.
> > > > >   Solution:
> > > > > In place, before "make install"
> > > > > petsc-dev/include                  same as now
> > > > >          /bin                      same as now
> > > > >          /conf                     basically the same as bmake/common was
> > > > >          $PETSC_ARCH/include       generated includes: petscconf.h
> > > > > petscfix.h ..
> > > > >                      lib           generated libraries
> > > > >                      bin           generated programs
> > > > >                      conf          basically the same as bmake/$PETSC_ARCH/
> > > > >                                       except not the include files
> > > > > prefix/include                  all includes
> > > > >       /bin                      all programs, including mpiexec, mpicc if
> > > > > generated
> > > > >       /conf                     the stuff previous in bmake/common and
> > > > > bmake/$PETSC_ARCH
> > > > >       /lib                      the libraries, including from external
> > > > > packages
> > > > > The whole trick is that in the PETSc bmake files (now conf files :-)) the
> > > > > $PETSC_ARCH/
> > > > > disappears in the "make install" version.
> > > > > I have fixed the external packages MPI.py, BlasLapack.py and Chaco.py but
> > > > > the others
> > > > > need to be modified to stick their libraries and includes in the new correct
> > > > > place.
> > > > > The only change you should need to your makefiles is to replace
> > > > > include ${PETSC_DIR}/bmake/common/base with
> > > > > include ${PETSC_DIR}/conf/base
> > > > > Bug reports to petsc-maint at mcs.anl.gov questions to petsc-dev at mcs.anl.gov
> > > > >    Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
