changes to MatSetOption() in petsc-dev
Lisandro Dalcin dalcinl at gmail.com
Mon Jul 9 15:21:56 CDT 2007
On 7/9/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     I have pushed a change to the MatSetOption() function.
Barry, a couple of comments
* I think MAT_NO_NEW_NONZERO_LOCATIONS should be
MAT_NEW_NONZERO_LOCATIONS, for symmetry with the other option names.
* I think all the MAT_INODE_LIMIT_[1..5] could be perhaps removed from
MatOption, and add a new function MatSetInodeLimit(Mat A, PetscInt
limit). Not sure what to do with  MAT_USE_INODE. Perhpas it can be
also removed, and use the previous function (with limit==0, no inodes,
and with 1 <= limit <=5, use inodes with that limit)
* You removed the MAT_[ROW|COLUMN]_SORTED stuff. I think you should
keep it, even when this feature is not yet implemented.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
