changes to petsc-dev directories
Fri Dec 14 20:58:53 CST 2007
    Very valid point.
    Barry
On Dec 14, 2007, at 7:37 PM, Dmitry Karpeev wrote:
> If maint/ is going into bin/maint/, I think config/ should also go
> to bin/config/
> (I think someone already suggested it).  The reason is that these
> are auxiliary scripts
> used to configure and build PETSc.  Their output -- the actual PETSc
> configuration --
> goes into conf/ and ${PETSC_ARCH}/conf and everything makes sense.
> Besides, there is no need to install bin/config/ and violate one
> standard or another,
> since an installation implies a particular configuration, which is
> already in
> conf/ etc.
> Dmitry.
> On 12/14/07, Satish Balay <balay at mcs.anl.gov> wrote:
> Reforwarding e-mail blocked by majordomo [reason: ^config is special
> command to majordomo]
> Satish
> ---------- Forwarded message ----------
> From: Barry Smith <bsmith at mcs.anl.gov >
> To: petsc-dev at mcs.anl.gov
> Subject: changes to petsc-dev directories
> Date: Sat, 8 Dec 2007 21:55:10 -0600
>      I have moved python/PETSc to config/PETSc and python/
> BuildSystem to
>   config/BuildSystem
>   in addition I have moved the maint directory to bin/maint and
> removed
>   conf/rules.basic.shared
>   After your next hg pull do:
>   mv python/BuildSystem config
>   rm -rf python
>     Any user makefiles and code should not need any changes
>       Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20071214/daad2d07/attachment.html>
