change to Fortran PetscTruth in petsc-dev
Thu Dec 6 19:49:04 CST 2007
    I have changed the definition of PetscTruth in Fortran in petsc-
dev to
logical*4. This will require small changes in Fortran code, for example
if (flg .eq. PETSC_TRUE) would become if (flg)
For backward compatibility you can put a #define
PETSC_FORTRAN_PETSCTRUTH_INT 1 into
PETSC_ARCH/conf/petscconf.h
    Barry
