Using complex from C code
Fri Jun 30 08:31:26 CDT 2006
    Mathieu,
     Cool, thanks.
    Satish,
     Could you please apply the diff to petsc-dev now and then push
so any future changes anyone makes will be combatiable with the new
code.
     Thanks
      Barry
On Fri, 30 Jun 2006, Mathieu Taillefumier wrote:
> Good morning everybody,
> I finished to modify the code of the library in order to compile the
> complex version with a C compiler. A few numbers of files have been
> modified. This modifications include a modification of the file
> language.py where I put in comment two lines forcing to compile the
> library with a c++ compiler. Since I don't really know python, I just
> put them as a comment, but i think it is better to put a message
> indicating that compiling the complex version of Petsc needs a C90
> compliant compiler (gcc 3.4 and after work, it works also with icc) and
> is experimental. Actually I am working with this modifications and it
> seems to work like a charm (I had no problem with it).
> I still need some time to convert the example programs which do not
> compile but it will be done soon.
> Note for all of us :
>    Don't use the name I as a variable anymore. It is a reserved word of
> the language.
>    For most of us, the modifications must be transparent.
> Regards
> Mathieu
