testing petsc-dev for upcoming release
Thu Feb 2 00:47:57 CST 2006
PETSc Dev users,
We hope to make a release tomorrow [friday]. This is a call for help
to test configure.
This is regression testing to make sure petsc-dev configure works for
all working 2.3.0 installs
So, try building petsc-dev with the _equivalent_ configure options
that worked before for petsc-2.3.0. If this doesn't work - let us know
[at petsc-maint at mcs.anl.gov]. Previously used configure command can be
obtained from petsc-2.3.0/bmake/$PETSC_ARCH/configure.py
petsc-dev tar file is located at:
ftp://info.mcs.anl.gov/pub/petsc/petsc-dev.tar.gz
[Configure] changes are listed at:
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/changes/231.html
Satish
