patch for seqdense
Hong Zhang hzhang at mcs.anl.gov
Fri Sep 2 15:41:50 CDT 2005
Simon,
I tested MatMatMult* using a new file
petsc-dev/src/mat/examples/tests/ex104.c.
Why you did not implement
MatMatMultSymbolic_SeqDense_SeqDense()
and
MatMatMultTransposeSymbolic_SeqDense_SeqDense()?
Did you use inplace mat product in your python test?
I added implementation of these routines. The tests run
well. The update code and ex104.c have been pushed
to petsc-dev.
Thanks for the contribution,
Hong
On Mon, 29 Aug 2005, Simon Burton wrote:
> On Sun, 28 Aug 2005 09:29:26 -0500 (CDT)
> Hong Zhang <hzhang at mcs.anl.gov> wrote:
> > > I sent through a patch to implement MatMatMult* for seqdense matrices.
> > Where is this patch? through bk or an attached file? I don't see
> > MatMatMult_seqdense from
> > petsc-dev.
> > Also, do you have testing code for it? I can test it
> > once I see the MatMatMult_seqdense.
> We tested it using python. I see also there is a test in src/mat/examples/tests/ex94.c .
> Simon.
> Simon Burton, B.Sc.
> Licensed PO Box 8066
> ANU Canberra 2601
> Australia
> Ph. 61 02 6249 6940
> http://arrowtheory.com
