tracking petsc
S V N Vishwanathan vishy at mail.rsise.anu.edu.au
Thu Nov 3 20:22:19 CST 2005
Hi!
Satish> But currently petsc-dev list archives are available only locally. And
Satish> petsc-maint is a 'bug-tracker' - not a mailing list. The archives of
Satish> this are also available locally only.
Satish> I'm checking if we can upgrade to a better bug tracker - with both
Satish> public/private entries [like bugzilla]. But....
One thing I can highly recommend (based on our experiences so far) is to
use plone. It has all the right combination of tools viz.
* bug tracker
* mailing lists
* release managers
etc. which can make you life rather easy. We have switched completely to
plone (http://lineal.developer.nicta.com.au which will be live in a day
or two once our legal dept has drafted a fat disclaimer :) ) and are
rather happy with it. If you guys are interested we can provide you with
more information/help on setting things up. Justin is our local expert
on this.
vishy
   The only skills I have the patience to learn are those that have no real
application in life.  -- Calvin
