[petsc-announce] petsc-3.5.4.tar.gz now available
Tue May 26 11:46:28 CDT 2015
Dear PETSc users,
The patch release petsc-3.5.4 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
 * Mat: Fix issue where the nonzerostate of Mat_MPIAIJ did not
   monotonically increase when matrix entries are zeroed in B.
 * Mat: bugfix for MatPtAPSymbolic_MPIAIJ_MPIAIJ()
 * DMDA: DMDAVTKWriteAll_VTS - Fix handling of higher-dimension
   coordinates
 * MatNestGetISs: use custom fortranstub to handle PETSC_NULL_OBJECT
 * Sys: fix PetscSubcommSetTypeGeneral wrt zero-ing the subsizes array
 * PetscEnumFind: Fix wrong counting of entries in list
 * configure: fix failure with --with-batch=1
 * MatLoad_SeqDense() always allocated new space for the data even if
   the user already provided it
 * Added PetscBagRegister64bitInt()
 * Removed direct use of HDF5_NATIVE_DOUBLE to support single
   precision as well
 * DMShell: destroy local to local scatter
 * Fix for ISGlobalToLocalMappingApply() for when it has a block size > 1
 * bugfix for MatGetRowIJ_SeqSBAIJ()
 * PetscDrawLGDraw: draw and flush only in process zero
 * PetscDrawSetType: Check the draw type is registered before destroying
 * TS: Use %g to draw time in TSMonitorDrawSolution()
 * PCMG must set initial guess nonzero for down (pre) smoother when
   using full or Kaskade multigrid because otherwise it zeros out the
   interpolated solution from the coarser level
 * Ensure the DMDA PetscViewerBinary writer using MPI-IO functionality
   respects the skip header flag when wither writing or reading files.
 * Added checks to enable loading of a vector which was written
   without the binary header.
Satish
More information about the petsc-announce mailing list
